Message 1 of 5
Re: Delete old account
Can i also delete an old account?
4 REPLIES 4
Message 2 of 5
HI Andy32, The quickest way of fixing this is to set up another BTID with an email address that has not been used as a BTID before and it will work ok.
If you don't have another email address you can use I've sent you a Private Message so you can get in touch with the Mod team and we'll raise the request to get the current BTID fixed.
Cheers
John
Message 3 of 5
Hi Andrew, I just wanted to check if you've had a chance to se up your BTID and if so is it working ok?
Please reply back and let me know and if you need further help I'll be happy to help you.
Cheers
John
Message 4 of 5
Hi John
Sorry yes all sorted thanks for all your help.
Message 5 of 5
Great stuff @Andy32
I am pleased you're sorted now.  I'll let @JohnC2 know you've posted back 🙂
Thanks,
Robbie
