Message 11 of 16
Re: Switching provider
How do I back them up? Can those hard disks be removed/ can i hook it up to my laptop
Message 12 of 16
@garybs29wrote:
Yes 100%. You can't have tv without broadband so it stops too. If it's been mentioned before it must be issues with it not cancelling correctly
You are correct, you can not have TV without broadband but the contract does not get cancelled by OTS so you must cancel it other wise you will still be billed for it because the contract is still running even although you can not watch it.
Message 13 of 16
So I rang them most they could knock off was £3. The chap was very nice but as a new customer I can get the same deal for £46.99 not £76.99 if I recontracted. He even said have been with them 9 years, no loyalty. Maybe theyll ring back ill give it a couple of days
Message 14 of 16
"If you have stuff you want to keep I suggest you back it up."
Actually I don't think there is any way to back up recordings stored on any TV Box/PVR, short of physically removing the hard disk and mounting it to a desktop computer, and then copying from that.
The only other method is to play the recordings in real time and use another PVR to record them, but that is very time consuming.
Message 15 of 16
 well i switched this evening..£17 broadband versus £47.99 per month. I will double check when my new provider activates tv services etc that BT have cancelled but their email.says it does. I should also say I'm sorry to go but 9 years and absolutely no loyalty, and not even a decent haggle, they clearly didnt care.
Message 16 of 16
No, they don't care about loyalty, but you'll find it's the same with all of them today so I would be prepared to move again in two years time.  That's the way it is today, sadly.  Good luck.
