Message 31 of 50
Re: Cannot access MyBT
I logged in via my phone app a few minutes ago & it loaded instantly & worked as normal, my open upgrade order was correct.
I've just tested it from my laptop & I logged in but it took a few seconds & then about 30 seconds before the dashboard was fully loaded.
Message 32 of 50
Re: mybt.com is down for few days
This is strange. I have just logged in to My BT account without any problems and have now been able to examine all aspects of my account i.e . Broadband, Landline etc. etc. I'm doing this on my laptop using Chrome browser. It was a little bit erratic earlier this morning when the bouncing balls produced nothing. That aspect is still a bit sluggish but it works.
Message 33 of 50
Looks sorted
Message 34 of 50
Yes, it all started to work again for me since 11.16AM, can access all pages in MyBT.
Did not change any password or changed anything, I did not even clear the cookies this morning, so I can assume BT has fixed it, hopefully it will stay this way from now on.
Message 35 of 50
I've logged in several times over the past few days without any problems.
Message 36 of 50
@caravanj
It's seems to me 4 days ago BT has changed something in their system but did not test it across all the devises & operating systems, that's why it still worked for some users but not for others as that would depend on the devise/operating system you use to access your MyBT or email.
Message 37 of 50
I very much suspect it was more likely to have been a problem with one particular machine in the server farm rather than user device.
Message 38 of 50
Re: Unable to log into MyBT
I can login now but it's still not working 100%. It's also slow loading.
Message 39 of 50
Re: Unable to log into MyBT - again!
cannot get into my email via login or my bt - just get a page telling me BT etc etc
Message 40 of 50
same here, I'm in Cornwall!
