Message 1 of 3
return bt kit
hi, i had an error when i ordered fttp that cancelled the wrong line, i got it stopped and then re ordered and the sh2 that had meant to come with first order was added to the second correct order.
my question is i have a timer now counting down to retun the sh2 that i am going to be using from tomorrow, can i just ignore the return kit part as i will need it for the fttp or will i be charged as soon as that countdown finishes?
2 REPLIES 2
Message 2 of 3
Re: return bt kit
Hi @Desalater,
I think it would be best if we took a look into this for you to make sure that you don't get any charges that you shouldn't.
I will send you a private message now that you can reply back to me on.
DanielS
Message 3 of 3
Re: return bt kit
thanks, pm sent
