Message 51 of 310
Re: BT Cloud - ERROR UN1
Absolutely, same issue. Experienced it a couple of times yesterday but was always able to get access at the 2nd attempt. Today, it errors on every attempt. I've logged it with BT but not holding my breath...
Message 52 of 310
Message 53 of 310
Re: BTCloud Error UN1
Their advice is nonsense. I have been using the cloud desktop app and web app for a while on Win11. There is a specific issue with the UN1 error which I've seen intermittently over the past few days but today looks to be much worse/widespread. The same error appears on my Android app which rules out their poor advice on Win11.
Message 54 of 310
I've resolved it. Simply reset my main BT ID account password and now able to login to BT Cloud.
Message 55 of 310
Message 56 of 310
So glad I found this thread.  So I am not the only one.  Usually I get in after 5 to 10 attempts.
Today - nothing.
Is there any chance that anyone from BT will ever read this and fix it?
Message 57 of 310
@NeilO Neil, hi, I'm also experiencing this fatal error. Can this be escalated please - I have no access to BT Cloud.
Continual UN1 error.
Please advise.
Many thanks
Message 58 of 310
Look, for me it does not work on Linux, MacOS or Android...
Message 59 of 310
Error code UN1
I've lost access to BT cloud weeks ago now, no way to get in via android apps or web browsers.
I'm aware there are multiple users complaining of the same, I was wondering if I need to raise some kind of support ticket.
Message 60 of 310
Hi Everyone,
Thank you for posting. I'm sorry if you're having problems accessing your BT Cloud. I've flagged this to the Cloud team for investigation and I'll post back as soon as I know more.
Thanks,
Paddy
