Message 21 of 31
Re: Norton Password Manager - Vault is now empty!
Just checked again this morning and its broken again.
well done norton
Message 22 of 31
Is it still broken mine seems to be working ok?
Message 23 of 31
its ok now. but for a couple hours this morning it was messing me about again.
I have now transferred all my critical stuff elsewhere.
Message 24 of 31
@sandCanoe Good idea, I use a backup app as well just in case
Message 25 of 31
Hello Neil, I am having the exact same problem. How can I fix it? Can you help?
Message 26 of 31
With the NORTON PASSWORD MANAGER
Message 27 of 31
Well, this has now happened to me. Fantastic. Any idea how this gets fixed?
Message 28 of 31
Maybe just a temporary bug i would give it a bit of time hopefully Norton will fix it soon
Message 29 of 31
Lo and behold, my vault has now returned - all my data present and correct. But it was a terrifying few hours when it went AWOL. Lesson learned - Norton Password Manager is a bag of spanners. Back up your data folks!
Message 30 of 31
Norton Broke for me too this weekend.. Luckily i was kayaking and it wasn't an issue this time.. To be honest i'm tired of complaining about it, BT support and Norton support are very unhelpful on this issue.
I am using NordPass for work critical stuff duplication, and both Noton and the NordPass extensions seem to play nice together.
I suggest not using the same e-mail and password for the different manager acounts.
