Message 1 of 12
Norton
I am so confused how do i changed to Norton everytime i try this comes up
Error Description:
ljuoKxtMbsZKR/uPJdfJsJGKplTkFs5P2Qs2DxwtEsd4oro8sUeSP9Yu/rqR1ERLajuETdlLkYUZXzgsMz5Be3AexOzfOp34+tb6+O7bY87NtUCJ18Ya6mCw2c4AC+Jhm9cUCixQe38dlwCaNexBPIzrmWicuXqQDPZolV2peXEKeuFmF2HruODKiXRvIMhnE61YLWP7S67fUUjknxJfVxuJnxxns2oK+I31Y75p23YV8Z3ZL5rKH/DJhDm6WO14a093ZUUSUjC6cG9tY4N9yVgwh6ID2UshzonYGPGmrgmrdhe2a7MxXDeJEpodMZkS73ZZzwiTMTkupX/6AeLtBQ==
11 REPLIES 11
Message 2 of 12
Re: Norton
Hi, @Bean Thanks for your post. I'm sorry to see you're having problems changing over to Norton, does it say 'Server error' or “The resource you are looking for has been removed, had its name changed, or is temporarily unavailable” before that code?
Neil
Message 3 of 12
Re: Norton
Hi
Thank you for your reply
its says
SERVER ERROR
Message 4 of 12
Re: Norton
SERVER ERROR
Please try again or contact Member Services & Support.
Error Description:
Y4fM/S4AocEEkxHGSvC3Msk3NTX+a+iqoFHqBa9J8V1kcGIQUd59IF0OEkzWPR7Xj8h17HfMBB9K2N6wtms1+CbOeYxEV13zVbI7i6IrAa1fPJAf20l7oIFzdjffvFLobSTkKPFll7Nmodk9uS41qbeY3T4rnIk/YezJ2OIDPNycWm5ciJw63KjyTqThEwFHre6qhV2PJeuI5DB7TiGeBx9y274ma+gKVyyHAwamgBSmvgm98OmhvkjIhnOov4nleU7nE7PMo4Cm4LciYUnKfCj/UMtAhp8CvOOCwqv42NRKJ1WPooYoCKmSQ2b3An1qkLGVjbVICzw0iwSv0j1xoQ==
Message 5 of 12
Re: Norton
Hi, @Bean Thanks for getting back to me, are you logging in with the BT ID that has account holder status?
You can check that by logging into MyBT clicking Your details then Account.  Scroll down and it will show if your BT ID has account holder or account manager status.
If it shows account manager there must be another BT ID with account holder status already claimed. If you don't know what that is you can click 'I should be the account holder' to change it over.
Post back and let me know how you get on.
Neil
Message 6 of 12
Re: Norton
My account is link to two accounts one is Account Holder
and the other is account Manager
I am not sure if this is the problem
Message 7 of 12
Re: Norton
Sorry forgot to say I have tried using both the accounts to change to Norton
Message 8 of 12
Re: Norton
@Bean is the BT ID for the one that has Account holder status in the format of an email address?
Neil
Message 9 of 12
Re: Norton
one of them is
the other
a bt address
Message 10 of 12
Re: Norton
Hi
The Account Holder is ******** and the BT address is the Manager.
