Message 1 of 5
Parental Controls
Hi,
I am having issues in managing my parental controls settings.
In short, they are active, but I do not have any access to "manage my extras".  Under "my security" it still says to activate them, yet they are already active so I also have no way of disabling them.  I have tried factory resets on the hub and also clearing cookies and differing browsers.
I would be grateful for any assistance you can provide.
Kind regards
4 REPLIES 4
Message 2 of 5
Re: Parental Controls
Try using the MYBT app and see if you get access that way
Message 3 of 5
Thank you for the response.  Should have mentioned the app is no help either as it has the same problem.
Message 4 of 5
Regrettably I still do not have access to managing parental controls.  They are working, however I have no access to manage them, or unactivate them as my profile still says "activate" when going to that area.
Any assistance would be very much appreciated.
Message 5 of 5
Hi @craigh279 I'm sorry about that, I'll send you a private message so you can get in touch with the moderation team.
Neil
