Message 1 of 19
BT answer machine doesnt work with Digital
I have recently been converted to BT Digital Voice which I understand uses its own Voicemail functionality. However, my BT Advanced Phone Answer Machine is now not working. What do I have to do to fix this so that I can use the answer machine?
18 REPLIES 18
Message 2 of 19
Re: BT answer machine doesnt work with Digital
Message 3 of 19
Set the number of rings on 1571 to maximum and your answering machine to fewer, as described in the FAQ.
Message 4 of 19
Thanks for this. The options for number of rings on 1571 are not numerical but on the BT Advanced Phone/Answer Machine, they are numerical, so how many rings do each of the 1571 options correspond to?
Message 5 of 19
If you go into MyBT and take a look under your products they are numerical.  I seem to recall that the default is 7 and the max is 10 rings.  My own answer phone is currently set on 5 and works just fine.
Message 6 of 19
if you go to MY BT then manage and digital voice you will see number choices available
Message 7 of 19
Max and 7 works just fine.
Message 8 of 19
Hi @clivecheshire These are the choices you get in MyBT for the number of rings and time it takes before 1571 voice mail kicks in.
Neil
Message 9 of 19
Many thanks Neil !
Message 10 of 19
Hi,
Mine is the same ! I have set 1571 to longest rings and my phone to shortest but still won't record a message.
Do i need to update my phones to later model  ? I currently have BT3880 Trio.
Many thanks
Peter
