Message 11 of 14
Re: BT lost my landline number
I called earlier today and they said there was no way for them to request the old number back on their system.
Hopefully a moderator may be able to help me, thank you.
Message 12 of 14
@Jass4
A renumber request should be straightforward for the main helpdesk to do, there would normally be a small charge?
I have asked a moderator to assist, as it may involve some extra work, that cannot be dealt with by the robotic tools that the helpdesk use.
Message 13 of 14
@Keith_Beddoe Thank you
Message 14 of 14
Hi @Jass4,
I have sent you a private message so we can take a look into this for you within the next 5 working days.
We will check everything that we can for you.
Thank you
DanielS
