Message 1 of 6
DV contacts
Some months ago, when renewing my contract, I was moved to Digital Voice. When setting the system up, I moved my contacts to the hub, and when one of them called me, their name showed on the handset screen.
However, some weeks ago, I had a problem with one of the handsets, and it was replaced by BT. Since the replacement, although the contacts number shows, when they call,  their name does not.
Anyone any idea's?
5 REPLIES 5
Message 2 of 6
Re: DV contacts
Message 3 of 6
Re: DV contacts
When you imported the contacts to the hub were they in the correct syntax?
BEGIN:VCARD
VERSION:4.0
FN:Fred Bloggs
N:Bloggs;Fred;;;
TEL;VALUE=uri;TYPE=home:tel:01nnnnnnn
MEDLODY:0
ACCOUNTID:0
DFTNUM:0
OWN:0
END:VCARD
Message 4 of 6
Re: DV contacts
Thank's for the reply liquorice. The contacts on the hub worked perfectly well, before the handset was replaced, and, for a while after. So, I assumed, that all was well.  Then, one day, the names disappeared. One of life's little mysteries which BT could not help with.
Message 5 of 6
Re: DV contacts
Hi @brimar   Just check that the telephone numbers are not formatted and are complete. That is a number like 02000 999999 should be stored as 02000999999, no spaces or formatting.
Message 6 of 6
Re: DV contacts
OK. I'll check. Thank's.
