Message 1 of 5
No link to the hub
My digital hub is working correctly but my phone says 'no link to the hub'.  If I go into settings, it will not allow me to scroll down to reset.
4 REPLIES 4
Message 2 of 5
Re: No link to the hub
If you go to hub manager can you see your phone number and active digital voice?  If so select phone number and       re-pair your phone to the hub
Message 3 of 5
Thank you.  I have registered one of my handsets and it's now working. (The  BT engineer did this before but it stopped working after two days.)  However, I can't register the other handset which I have upstairs.
Message 4 of 5
Did you try registering it when closer to the hub to see if it is a range problem rather than anything else?
Message 5 of 5
Yes, I stood right by the hub .  Also the digital phone that I did register will not allow me to scroll down.
