Message 1 of 11
Re: BT Smart Hub 2 DECT
I have gigaset c570hx handsets and an n300ip base station plus the BT smart hub 2 and their digital home phones. I turned off the n300ip base station and was able to register the handsets with the BT smart hub. But you seem to lose some of the functions of the gigaset base station. So what is the best way to do things?
This way you lose some of the gigaset functions, but if you continue to use the gigaset base station and plug the telephone line into the back of the smart hub, doesn't that mean you have an analogue connection?
10 REPLIES 10
Message 2 of 11
just connect base station to phone socket on back of SH2 and should work as before
read FAQ
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
Message 3 of 11
Digital Voice only refers to the section between the network and the BT Smart Hub 2. The socket on the back presents an analogue interface because the conversion from digital to analogue takes place inside the Smart Hub 2. The hub also forwards the digital signal over DECT, which is why the BT provided handsets give better quality.
Message 4 of 11
I have a similar setup. My conclusion is that it is best just to plug the base station into the back of the Smart Hub 2. You will lose your directory of contacts from the Gigaset from the extensions that are linked to the Smart Hub 2. I've got some of the Smart Alexa phones but I prefer the Gigaset extensions.
Message 5 of 11
Why would plugging the Gigaset base station into the SH2 remove contacts in the Gigaset handsets? It doesn’t in mine and I would not expect it to. The Gigaset base station doesn’t know or care if it’s connected to copper or  SH2.
Message 6 of 11
No the other round. If you register a Gigaset handset directly onto the hub, then that handset does not have access to the directory stored on the Gigaset base station.
Message 7 of 11
Why would you do that? It makes sense to register Gigaset phones with the Gigaset hub so you keep the functionality of the Gigaset system.
Message 8 of 11
Hello,
I also have the N300 and C570H but I'm not having any luck when plugging the n300 into the phone port on the base. No calls can be made or received.
Is there any setting I need to change on the system for it to function?
Thanks in advance.
Message 9 of 11
Have you been converted to Digital Voice or does your Analogue copper line still work?
Message 10 of 11
Ive been converted to digital voice
