Message 21 of 27
Re: Connecting to WiFi
I have AP on the display and have connected my phone to the WWS wifi  but my laptop won't go into the 192.168.1.1 page.
If your phone is connected to the WWS WiFi, then you can use a browser on your phone to go to 192.168.1.1.
If your laptop is connected to WWS WiFi, then use a browser on your laptop.
You need to use a browser on whichever device is connected to that WiFi.
Message 22 of 27
Wow, just did this and got this page up: Many thanks ptrduffy!!
Now feel I'm getting somewhere!
Obvious next question, where do I find all the information it's asking for  🤔
Message 23 of 27
Now I'm getting a bit nervous in case I screw up the whole WiFi network🥴🥴
Off to bed until tomorrow.
Thanks so much for your patience, really appreciated!
Message 24 of 27
Here's a bigger image of the 192.168.1.1 webpage I have managed to get to🤣
Now just need to know where/what all the required information can be found.
Message 25 of 27
I presume Router/Password are my wifi credentials from the BT Hub - no problem.
No idea where I find the Weather Underground or Weather Cloud information?
Will the station only work into the Wunderground App? I notice one has to PAY for the upgraded version at almost £4 a month! That is not in my budget!!
Message 26 of 27
Congratulations 😊
I'm afraid I can't help you on the Weather Underground - I suspect you'll need to find a weather station forum for assistance with those aspects of things.
Please don't forget @licquorice 's previous comment regarding the Weather Station IP address.  I don't see anything on the screen you posted about this, but there may be something in the 'Advanced' page?
It's possible that the device only uses the 192.168.1.1 address when in AP mode, and uses DHCP to get an address from the Hub once 'properly' connected, but it would be good to confirm this before connecting it to your Hub.
Message 27 of 27
"It's possible that the device only uses the 192.168.1.1 address when in AP mode, and uses DHCP to get an address from the Hub once 'properly' connected, but it would be good to confirm this before connecting it to your Hub".
I think that is the case but I'll check with the manufacturer/supplier. I seem to remember something like that.
Once again, thanks.
