Message 31 of 68
Re: Connection cutting out
@VINC3
On the advanced menu.
Operation mode - should be Access Point
Fast roaming - disabled   (its not compatible with many devices and causes disconnects)
Beamforming  - enabled
If you have BT TV, then you will have to leave it in this mode when you get FTTP, as you will still need to use the BT Smart Hub 2.
Message 32 of 68
@Keith_Beddoe
Thank you.  Does this tell you/me?  Doesn't seem to correspond with what you have advised
Message 33 of 68
@naylor2006
Thank you and apologies again.
Message 34 of 68
No need to apologise, you might wanna charge your phone though.
I think your DECO is in the wrong mode.....its in Router mode when your BT Hub is the router, you should change it, but ill let @Keith_Beddoe confirm.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 35 of 68
@Keith_Beddoe
Thank you
So change mode to Access Point?  But I cannot see 'Beamforming'?
Message 36 of 68
@VINC3
You are in the wrong mode, so I am surprised that you do not get more issues, especially with gaming, as it would not be possible to get Open NAT.
You can change this to Access Point mode. The system will reboot, so make sure that nobody is connected to the Deco.
You will lose the other menu options, as they are not applicable in Access mode.
After reboot, devices will be issued with new IP addresses from the Home hub subnet.
Message 37 of 68
@naylor2006
@Keith_Beddoe
Ha!  Thank you, I will get phone on charge asap. 😄
Message 38 of 68
@Keith_Beddoe
Thank you.  I have updated to 'Access Point'.  Can you please advise if below looks correct?  I cannot see an option re the other update you advised?
Message 39 of 68
@VINC3
Its just unfortunate that the initial setup of the Deco, is very confusing, and is really aimed at cable routers, so it defaults to router mode. It has to be changed once a connection is established.
I would tend to leave it in Access Point mode, even when you get FTTP, as you are going to need to keep the home hub connections for BT TV.
Its not going to work in router mode on FTTP if connected directly to the ONT, without entering PPPoE credentials, so its best lest in Access Point mode for simplicity, especially if you have any issues with the FTTP connection in future.
Message 40 of 68
@Keith_Beddoe
Thank you so very much
I do not have BT TV and I totally agree, the initial set up of the Deco was very confusing and unnecessarily confusing.
Can you please tell me if below looks correct and should I be looking to find 'Beamforming' - that you mentioned previously?
