Message 1 of 9
No wifi
Hi,  my smart hub 2 is not  showing up as wifi on any devices. I have plugged in an Ethernet cable and it works ok but need wifi in the house.
How do I get to speak to someone on the phone as it seems really difficult?
8 REPLIES 8
Message 2 of 9
Re: No wifi
has this just happened and was ok before or is this a new SH2
have you checked with mobile phone that you cannot see any SSID from the new hub when you go to wifi connections in mobile phone
Message 3 of 9
Re: No wifi
Yeah, it’s just happened. Been working for 1 year with no problems.
I have tried several mobile phones and the tv. Laptop not seeing the wifi for the router either.
I have just carried out a factory reset. Can only access broadband via Ethernet cable.
Message 4 of 9
Re: No wifi
And how do I log this as a faulty router?
Message 5 of 9
Re: No wifi
Call 0800 800150
Message 6 of 9
Re: No wifi
Tried that number a few times. It just sends a text to start a diagnostic and then ends the call.
Message 7 of 9
Re: No wifi
Hi @jimb2 Thanks for your posts, I'm sorry to see you're having problems with your Hub. Did you manage to get this sorted?
Neil
Message 8 of 9
Re: No wifi
Hi,
No not yet, I filled in an online complaint form and have a reference number to say they are looking into it.
still on access the internet via Ethernet cable. No wifi showing.
Message 9 of 9
Re: No wifi
Hi @jimb2 thanks for getting back to me, the quickest way to get this sorted would be to get in touch with the broadband faults team, you can request a callback or live chat with them using the links on this contact page.
Neil
