Message 21 of 54
Re: Wi-Fi on halo 3 do not pass 145 download
Ok will do. Thanks a lot.
let us see what happens when things are quiet.
Message 22 of 54
Message 23 of 54
Tested now. Still same speed.
Message 24 of 54
Is your machine connected directly to your hub or does it go through a network switch/port expander
Message 25 of 54
Hello Les.
thank you for your help.
it is Direct to the Hub
Message 26 of 54
Hi everyone!
any new idea of reason why I can’t pass the 145 Mbps on my BT home hub 2?
Message 27 of 54
I see your hub is running firmware V0.33, try the following
First login to your hub and enter the Admin Password then click this link and make sure Smart Setup is Off
Message 28 of 54
Thanks a lot. Shall I click on the link from my browser?
Message 29 of 54
yes
Message 30 of 54
Done. Smart set up is off
