HomeHub4 - ability to manually assign fixed IP addresses
Hi,
The HomeHub4 can retain IP addresses for devices once connected but these IP addresses are only assigned in the order that the devices are registered. I have a number of PCs that run software that require each device that they talk to to have an assigned and fixed IP address. These were set up under a different router which allowed me to manually assigned fixed IP addresses. The HomeHub4's limitation in this respect means that I now have to individually remap each device on each PC rather than make the assignings in one place (within the router).
I would like to propose that the HomeHub firmware is updated to allow the administrator to manually reserve IP addresses for connected devices identified by their MAC address.
Dave
