Turn off captcha in Bt Yahoo
how **bleep** annoying to have to put a sometimes unreadable captcha code everytime I send an email.....and whats worse it can't be turned off...for pits sake BT OR YAHOO or whoever thought this up give us the option to turn the **bleep** thing off.
2 Comments
thecrookies489
Totally agree mazroy, I get exactly the same.  And then you can't get email on your ipad or iphone because it says the user details are incorrect!
vofsanity2
Recognised Expert
Captcha is an essential feature. If you are having the issue you describe than it is likely that you have another problem that you need to resolve. I suggest you raise getting a Captcha so frequently as an issue under the appropriate category.
