Message 21 of 32
Re: Windows cannot login with BT TV player
OK thanks. So it seems your device is reporting that it doesn't support the encryption that our content uses, however that would be surprising.
We've got a couple of things to try, and we're also going to put together some self-help for this in future, however for now, would you mind please checking this web site using the Edge browser on your Windows PC?
https://bitmovin.com/demos/drm
Towards the bottom of that page you'll see something like this:
It's specifically playready that we need to confirm works OK.  Is it ticked for you?
Message 22 of 32
Thanks, no only widevine is ticked. playready, primetime and fairplay are not.
Edge is updated to the latest version automatically, currently 100.0.1185.39
Message 23 of 32
I've also tried enabling it in edge://flags and restarting the browser, but still showing as unsupported.
Message 24 of 32
OK thanks, so that at least matches our investigations.  Could I ask you to try disabling Widevine and restarting?  It's a long shot, but there have been some reports that with both PlayReady and Widevine enabled, some systems fail on both.
edge://flags/#edge-widevine-drm
It's also worth checking edge://gpu to see if PlayReady hardware DRM is enabled.
Message 25 of 32
No joy after disabling widevine.
In edge://gpu I see that:
Version Information:
Command Line = ... --enable-features=msPlayReadyWin10 ...
Media Foundation Rendering Capabilities:
PlayReady Hardware DRM disabled = true
Message 26 of 32
OK thanks.
Did the previous BT TV app work for you on Windows? Were you able to play video with it?
Message 27 of 32
Yeah, not sure the last day i used it, but it worked fine when whenever that was.
Message 28 of 32
Unfortunately, at this stage I'm afraid to say that your PC most likely can't be supported. It's worth checking Windows Update to see if any driver updates are available for your display, but without PlayReady Hardware DRM being available, there's currently no way to make it work.
We're looking to support Widevine in a future update, however this is likely to be many months away.
We'll be updating the WP035 error to reflect this very shortly.
Message 29 of 32
could it be:
edge://gpu
Driver Bug Workarounds:
disable_playready_hardware_drm_25668132
Message 30 of 32
Yes, that's almost certainly the issue. Is your Windows 10 up to date? Google suggests that the bug referenced there was in an old build of Windows (2 years ago).
