Message 1 of 5
Bt whole home discs.
I’ve just purchased the whole home Wi-Fi kit and I have an another disc that came with my router. Should I set the whole home Wi-Fi discs app the through the whole home app or just add the 3 discs to my network through the my BT app?
If I do do it  through the whole home i will have two Wi-Fi connections (my original router and the whole home Wi-Fi)
4 REPLIES 4
Message 2 of 5
Re: Bt whole home discs.
The disc you received with your router is most likely a black one, also known as a Complete WiFi Disc, the two are not compatible
Message 3 of 5
@Pedrostar88
Welcome to this user forum for BT Retail phone and broadband customers.
Use the Whole Home app.
See https://community.bt.com/t5/BT-Devices/Problem-with-Whole-Home-Wi-Fi-Please-read-this-first/td-p/202...
Message 4 of 5
Am I better using the whole home Wi-Fi or buying extra complete Wi-Fi discs?
Message 5 of 5
@Pedrostar88
I assume you are a BT Broadband customer?
The Black Complete Wi-Fi Discs are on loan, and you can request two extra ones for free, as part of the BT Complete Wi-Fi promise. Its not worth purchasing them yourself, just in case you decide to use another provider in the future.
https://www.bt.com/help/bt-halo/what-is-complete-wi-fi-
You cannot mix those with the Whole Home Discs.
