Message 1 of 7
BT mobile abroad
Hi, I am unable to use my BT Mobile in Tenerife unable to call or text, just says “no service”
can anyone help?
6 REPLIES 6
Message 2 of 7
Re: BT mobile abroad
Did you activate the ability to use abroad in MYBT ? You also need to ensure your spend limit for Broad is greater than £0 say £5
Message 3 of 7
As @imjolly says, you need to activate roaming in MyBT, put an extra spend limit of at least £5 on the account and also enable roaming on the device if it's not already activated
Message 4 of 7
Hi, yes it is activated and spend value is £30
thanks for reply anyway
Message 5 of 7
Sorry but are you sure the abroad use is active with speed limit not just the UK use. This has come up often quite a few time and activation and spend limit solve the problem2
Is roaming active on your phone as well
Message 6 of 7
Once you’ve checked roaming is active, try searching for a network in your settings as you may need to manually connect. Movistar is usually the best available network in Spain.
Message 7 of 7
Hi, I have just done what you suggested and connected manually to Moviestar and it is now working!
Thank you very much 😊
