Message 1 of 4
I cannot claim my BT digital reward card.
Hi,
I have a £50 BT digital reward card which is well within it's expiry date but I cannot claim it. When I try to do so it sends me to the BT log-in page, and I can log in but then it takes me straight to a message that either shows no reward current or previous of says the page is not available. Customer services said that they would sort it a week ago but nothing has happened. Can anyone help please?
Thanks,
3 REPLIES 3
Message 2 of 4
Re: I cannot claim my BT digital reward card.
Hi @VeganFlea and welcome to our community.
I'm sorry you're having problems claiming your reward. I'm sure we can help you with this. I've dropped you a message so please check your inbox and drop me a reply with the details.
Cheers
David
Message 3 of 4
Thanks for sending over the details @VeganFlea .
I've sorted that for you now.
All the best
David
Message 4 of 4
Thanks for sorting this out David, by far the easiest resolution I've ever had through BT. Thanks again.
