Message 1 of 5
Refer a friend
Hi
I referred a friend to BT using the link provided
I received an emailing confirming that the referral was successful  last year
I haven't received the £50  amazon voucher nor has the person that I referred
They took out a broadband package which is still running
I contacted BT by phone and eventually, a member of the referral scheme team contacted me  to say that I didn't qualify citing an old email address as the reason (even though it was over 15 years since it was used in association with the account)
I emaied back and advised that I did not use that address and provided screen shots of the email from BT with my email address on it
I didn't receive a reply so I tried to send another email but it would not send this time as the address was not valid
I would appreciate a bit of help in resolving this issue
4 REPLIES 4
Message 2 of 5
Re: Refer a friend
Hi @MaggieMcG and welcome to our community.
I'm sorry you're having problems with the refer a friend offer. I'll be happy to look into this for you. Please check your inbox for my message and drop me over a reply with the details.
Cheers
David
Message 3 of 5
Re: Refer a friend
Hi @MaggieMcG
Thanks for sending over the details. That's all sorted for you now and you should receive the vouchers soon. Please let me know when you do.
Cheers
David
Message 4 of 5
Re: Refer a friend
Hi David, all sorted, we both received our vouchers
You did a great job getting this sorted and it is very much appreciated
Margaret
Message 5 of 5
Re: Refer a friend
Hi @MaggieMcG, thanks for the update and happy spending 🙂
Cheers
John
