Message 101 of 310
Re: BT Cloud 22.12.33 not working
@bucketbot1  and @Cicero Cicero
... or it could be that the issue is with Synchronoss (hard link below also to Mar 2016 press release) whom BT outsource to for this platform. I'm seeing errors on their website - is there a problem? Cursory research shows there stock price has tanked; this and other financial news over the years doesn't make good reading. Combined with silence from BT, just adds concerns.
https://synchronosstechnologiesinc.gcs-web.com/news-releases/news-release-details/synchronoss-powers...
Message 102 of 310
@User12345 @bucketbot1
Thanks for that, I recall when it was taken over. The product has never been comparable to the F-Secure original cloud offering .
Message 103 of 310
Re: BT Cloud - ERROR UN1
I have been trying for days. Was on to technical support for an hour today and got no response
Message 104 of 310
Hi all I have sent the necessary information to the BT Cloud support team, hopefully they can solve the UN1 issue.
One of the desktops is still working though it has not been logged out, nor will be.
In summary I have tried to login from 4 different devices using 3 different operating systems.
I can access MY BT account using the same login credentials.
Message 105 of 310
I tried to call, but the options offered to raise a ticket are limited to Bband, Phone, mobile or sport. Any idea on where to direct the call?
Message 106 of 310
BT Cloud is under Broadband
Message 107 of 310
  • @Cicero  @User12345 Probably why BT Cloud is no longer offered to new broadband customers. Clearly BT must have saved a few pennies by moving platforms. Why else would they have moved from a robust, reliable, easy to use  platform to the Synchronoss offering? 🙄
Message 108 of 310
Come on BT.
When are you going to get Cloud up and running ?
It's a bloody disgrace.
Message 109 of 310
@AJSH
Thanks it’s difficult to find on the My BT App from the App Store. Easier to find on My BT via the internet and log in.
Message 110 of 310
@cecco16
I emailed my problems direct to Cloud Support at [email protected]
Have not received anything back so far but it’s not been rejected either 🤞
