Message 11 of 16
Re: Xbox ultimate
Hey there, I can't see a place to add an account number unfortunately. I clicked through all of the options.
Message 12 of 16
Re: Xbox ultimate
Hey @Lukdz,
I am sorry that it's not showing up for you.
I think it would be best if one of our team looked into this for you. I'm sending you a private message that you can reply back to us on.
DanielS
Message 13 of 16
Re: Xbox ultimate
Thank you, replied. Also, I don't know if this is related, but I can never login to the mybt app. It always goes into something went wrong retry error message after logging in.
Message 14 of 16
Re: Xbox ultimate
Hi, @Lukdz it probably is related, thanks for sending over your details we'll get back to you in the next couple of days.
Neil
Message 15 of 16
Re: Xbox ultimate
Hi @Lukdz Thanks for allowing me to help get your BT ID issues resolved so you could activate your Xbox Game Pass.
Neil
Message 16 of 16
Re: Xbox ultimate
All sorted, thank you for the help!
