Solved! Go to Solution.
Hi @molar59, are you sending the email to only this user when you get this error?
Or is it one on a distribution list and if so how many recipients?
Cheers
John
Hi @JohnC2
Thanks for responding. The rejections started when the btinternet users were included in a mailing list (about 64 recipients). However the rejections continue even when the users are emailed individually.
Hi @molar59, thanks for getting back to me.
Are you sending from an @btinternet email address? There is a limit on the number of recipients of 49.
Check out Error 554 for further help with what can cause this error.
Have you tried sending an individual email to the address from a different IP address just in case the current IP is on a Blacklist?
Cheers
John
Hi @JohnC2
I'm sending from a Gmail address. Other Gmail addresses can send to btinternet addresses, only this Gmail address cannot send to single or multiple btinternet addresses.
I've tried sending from different IP addresses.
Perhaps this Gmail address is on a btinternet blacklist. I've sent an email to postmaster@btinternet.com but no reply.
Anything more you can do to help?
Thanks.
Hi @molar59, going to the Postmaster would've been the next step I would have recommended for you.
Cheers
John
Thank you @JohnC2 but as I can’t get a reply from postmaster this thread is worthless unfortunately. Any ideas how to get them to respond / un-blacklist my address?
This is preventing our organisation from communicating with a large number of people who have btinternet addresses.
@JohnC2 - 25 November.
Hi @molar59, they usually take longer than that to reply.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to see if there is any way we can urge this for you.
Cheers
John
