Message 1 of 9
Amazon devices
As of this morning, none of my Amazon devices will connect to the internet. I have 3 fire sticks and all are doing the exact same thing.
They can see the network but show "internet not available". I've tried factory resetting one and now that will not even connect to the WiFi as part of the setup.
Anyone having similar issues?
8 REPLIES 8
Message 2 of 9
Re: Amazon devices
which version of BT hub are you using?  has it had a firmware update which might cause problem?
Message 3 of 9
Re: Amazon devices
SH2, shows version v0.37.00.07084 updated about 3 weeks ago
Message 4 of 9
Re: Amazon devices
Just found some similar posts on down detector https://downdetector.co.uk/status/amazon/
Message 5 of 9
Re: Amazon devices
have you tried resetting the hub - not factory reset just now
Message 6 of 9
Re: Amazon devices
Tried reset and factory reset. It looks like an issue with Amazon from down detector.
Message 7 of 9
Re: Amazon devices
@lufc87
just checked my devices and they are offline as well
Anonymous
Not applicable
Message 8 of 9
Re: Amazon devices
Message 9 of 9
Re: Amazon devices
My Alexa devices are working fine.
My 4k fire stick has rather interestingly performed a software update -> and then immediately informed me of another, other than that it's also fine
