Message 1 of 55
Smart Hub 2 and splitting the 2.4ghz and 5ghz bands
BT are pestering me to plug in my Smart Hub 2 so I can keep using my landline, but it's been gathering dust in a cupboard for about a year because it doesn't support band splitting (which causes issues that I'm sure many are familiar with).
I was just wondering if they ever managed to fix this or if I'm about to lose my landline for good?
thanks!
54 REPLIES 54
Message 2 of 55
Re: Smart Hub 2 and splitting the 2.4ghz and 5ghz bands
You can't split the bands, but most/all of the problems are when setting up devices initially. The resolution is to turn off the 5Ghz band, set up the devices and then reinstate the 5Ghz band.
Message 3 of 55
If you need to use the SH2 have you considered turning off Wifi completely on the SH2 and using a different Wifi Access point? I you have an existing router that does provide Wifi as you desire, then provided you don't need to return it you could disable DHCP, set a static ip address on it (such as 192.168.1.1)  and link the two routers via ethernet.
Message 4 of 55
@countrypaul - thanks for the suggestion. Can I use my existing Smart Hub to do that?
Message 5 of 55
You should be able to use you existing Smart hub - yes (provided BT don't want it back). You also avoid having to reset the Wifi SSID/password anywhere that way, either on the SH2 or everywhere else!
Message 6 of 55
Make sure you turn off DHCP on the second hub
Message 7 of 55
thanks @countrypaul , I had no idea I could do that!
So, I just need to disable DHCP on the Smart Hub 2 and daisy-chain it to the Smart Hub 1 with an ethernet cable? Sorry, it's been a few years since I done stuff like this so I'm a bit rusty!
Message 8 of 55
Also make sure you change the IP address of your old hub to a static one different to the SH2 before connecting the two together or they might fight for customers trying to access the internet.
Message 9 of 55
That worked a treat!
@countrypaul  you are a 🌟 - thank you!
Message 10 of 55
A fantastic solution @countrypaul .
Kudos to you. 👍
Cheers
David
