BT speedtester simplification
Recently the BT speedtester has dsiplayed some additional input requests for me (though it stopped today)
This means a number of inoputs and confirmations thus
1 click to yes radio button confirm you have done that stuff on the first page
2 click on ADSL/Fibre to the cabinet speed test
3 enter your phone number
4 then asked if this is the correct number prompt yes/no
speedtester does some stuff, then...
5 then asked to tick radio box prompt and if you want to continue with a video service quality test -
6 then prompted to select continue or exit
This means I cannot go off and do something else and I must wait for prompt and respond
What I would like is
1 enter phone number
2 do test
How nice would that be ?
4 Comments
IanC
Recognised Expert
Whoops - didn't mean to "rate" this. I was looking at it on my mobile and saw a button labelled "ratings 1". I thought that by pressing it I'd see who'd rated it, but instead it changed to "ratings 2" !
john46
Hi looks like Wholesale  are trialling a new beta speed test  has no upload speed or ip profile though
KerryG
Community Manager - Retired
Status changed to: More Feedback Needed
Shrimper1
When I used the BT speedtester for tests 1 & 2 as an Orange subscriber, I found it pretty easy to use; however when it entailed moving to the next level (Test 3), and fiddling around with changing IP names, or whatever it was, well it did not work. I had another go a few weeks later, and "made it have it" .......... and success! However these public usage testers should be programmed to be more robust, as frustration leads to switching offSmiley Mad
