Clear the "Solved" flag from a thread
I had a problem with BT Fon. With help from the forum I got rid of it. So I marked the message that helped me as the solution. Yesterday, however, BT Fon reactivated itself! I'd like to clear the Solved flag from the thread.
http://community.bt.com/t5/BB-in-Home/Do-I-have-to-reset-my-HH2-to-get-rid-of-BT-Fon/m-p/133885#U133...
1 Comment
KerryG
Community Manager - Retired
Status changed to: Implemented
Hi Minusdot This feature already exists. As the original poster you have the ability to mark solved and also unsolved within the forum options. To mark as unsolved you go to the post you marked as solved, click on the options and select 'unmark as accepted solution'. Thx Kerry
