Marking a thread as solved should lock the thread.
Often a thread is incorrectly marked as solved when it isn't. Or it is, but the problem resurfaces. People get frustrated that a problem they're still experiencing is "solved".
If marking a thread as solved also locked the thread, then others would start a new thread - which could remain open until the new poster is satisfied.
7 Comments
pottyperson
Distinguished Guru
Distinguished Guru
I agree that a threads should be locked when marked as solved, with the proviso that the OP can reopen if necessary. Locking threads automatically after a certain time without a contribution is also worth considering.
vofsanity2
Recognised Expert
This idea has been raised at least twice before without getting any real support.
See
http://community.bt.com/t5/Forum-Guidance-Ideas/Marking-Threads-as-Solved/m-p/499609/highlight/true#...
Why it does not get more support is a mystery.
NigelE
Moderator-Retired
Status changed to: Considering
Thanks for this, I'll take some advice at our end to see whether we can take this forward - leave it with me and I'll update here as soon as I can.
ukfrogman
9 months on, any update available?
Happygoblin
I would have thought the optimum would be "Only the original poster can set a thread as 'Solved'" and for that to lock it
That way if I start a thread about an issue only I can set it as solved when I feel it has been.
If a day/week/month whenever its a "its happening again" I as the original thread creator can..."un-solved it "  !!
KenSharp
There is never a good reason to lock a thread.
vofsanity2
Recognised Expert
Can we have an update on this please ?
