MyBT Smartphone App
MyBT Smartphone App
It would be really useful if I could access my broadband usage and billing details using an app on my smartphone. Is there any intention of this happening?
14 Comments
StephanieG
Moderator
Moderator
Status changed to: More Feedback Needed
Thanks for the suggestion, sounds like a good idea 🙂 What does everyone else think? If you think it's a good idea click on the Kudos star. Stephanie
john46
Yes a great idea
ryant704
Guru
Support, like the idea!
dombullion
brilliant idea 🙂
A great idea IMHO
ryant704
Guru
The only problem I in my mind is the security aspect, as many people don't use AV on their phone and mobile hacking is on the vast increase due to the development with apps.
pottyperson
Distinguished Guru
Distinguished Guru
Is it necessary? On Android at least, you can bookmark MyBT or the BB usage monitor (possibly also your bill, I haven't tried) and set it as a favourite. Remember to log out after viewing if you want to be sure to keep password protection.
andypol
That's brilliant idea! checking the bill, usage etc. would be extremely helpful
rajinderpauluck
Most definitely agree with the idea
fullyresolved
Newbie
great idea
