Anonymous
Not applicable
Message 111 of 215
Re: EE “A new era”
SNAFU... 😁
Message 112 of 215
Re: EE “A new era”
@Moose_UK I was speaking to ee yesterday and the gentleman I spoke to said that most of the staff aren’t trained on the new EE. Sounds like you got one who wasn’t
Message 113 of 215
Re: EE “A new era”
@DarrenDev the message was on my landing page when I logged in to MyBT.
As I said, the advisor dismissed anything I had to ask about EE and just focussed on upselling.
Was this advisor incorrect? Should I call and try again?
After clicking the link on MyBT, I was presented with this number on another page;
@mirrors90 that makes sense. Might try again later.
(BT Full Fibre 900 -- 980mbps down :: 110mbps up)
Tags (1)
Message 114 of 215
Re: EE “A new era”
To be honest @Moose_UK , I’d wait ! There’s so much confusion , nobody can clearly advise the benefits etc. I’m giving it a short while to settle before I try!
Message 115 of 215
Re: EE “A new era”
Good shout @mirrors90 , I'll hold off for now.
Message 116 of 215
Re: EE “A new era”
If you already have BT TV then definitely don't bother - you can't upgrade without losing TV at the moment.
If you don't have TV then you could upgrade.
Message 117 of 215
Re: EE “A new era”
TV is with Sky still at the moment, just fibre and DV with BT. I'll sit tight.
Message 118 of 215
Re: EE “A new era”
My plan is to switch to EE TV once my sky runs out in Jan, as long as the UI is as good as sky.
Message 119 of 215
Re: EE “A new era”
Hi, @Moose_UK I'm sorry about the poor experience when you called, we'd like to take a look at this for you. I'll send you a private message so you can get in touch with your details.
Neil
Message 120 of 215
Re: EE “A new era”
I had the exact same thing today, I was expecting a call from them to discuss a possible upgrade. But so far no one called
