Message 1 of 7
BT Handset
Hi - after years (decades) of frustrations and ridiculous price rises I had no choice but make the switch to Sky. Now my (BT) Handsets are not receiving landline calls. Are they not compatible with Sky? Don’t see why they shouldnt work…
yep, ignore me. I had phone plugged direct into the phone socket rather than the router. Mis-led by my own logic.
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: BT Handset
No reason at all unless they're Digital Voice handsets.
Message 3 of 7
Re: BT Handset
try sky forum
https://www.sky.com/help/articles/sky-community-info
Message 4 of 7
Re: BT Handset
@Chippers
Welcome to this user forum for BT Retail phone and broadband customers.
What model of phones do not work?
Do they plug into a normal wall socket?
Message 5 of 7
Re: BT Handset
Thanks for the update @Chippers
Glad to see you got it sorted.
Cheers
David
Message 6 of 7
Re: BT Handset
@DavidM what was the update Chippers gave? It may help others.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 7 of 7
Re: BT Handset
Hi @Devon_Dave .
@Chippers updated his post with 'yep, ignore me. I had phone plugged direct into the phone socket rather than the router. Mis-led by my own logic.'
Cheers
David
