Message 241 of 310
Re: BT CLOUD ERRORS
I have now managed to log in on the desktop app and on the website access and also on my android phone, still on BT Cloud 22.12.33.
It's now busy checking & uploading all files since it broke
Message 242 of 310
Re: BT CLOUD ERRORS
Hi All, the BT Cloud team have confirmed that the UN1 error issue has now been fixed. Can everyone please try logging in again?
We are very sorry for any inconvenience caused while this was being resolved.
Cheers
John
Message 243 of 310
Re: BT CLOUD ERRORS
It worked ok for me a few hours ago. Thanks for the resolution
Message 244 of 310
Re: BT CLOUD ERRORS
Seems ok for me….thanks for getting it fixed.
Message 245 of 310
Re: BT CLOUD ERRORS
Up and running again on PC and App
Message 246 of 310
Re: BT CLOUD ERRORS
JohnC2, thank you for the help that you have provided.
JTS1
Message 247 of 310
Re: BT CLOUD ERRORS
Hooray, it is back up and running. Whilst it was off files were still backing up on the cloud for me so no need to go through the whole computer back up process.
Thanks to whoever fixed it, that is a relief.
John.
Message 248 of 310
Re: BT CLOUD ERRORS
Thanks @johnj @JTS1 @Scooter18 @Cicero and @VKB for letting us know this is sorted.
Cheers
David
Message 249 of 310
Re: BT CLOUD ERRORS
Seem to have a new fault. I can login via the web symbol on the desktop app. I cannot login using Chrome or Firefox, just get the message page not found with a screwdriver and a spanner..obviously a BT Message.
Have tried from 2 different PC’s on W10 .
Do we need a new thread ?
Message 250 of 310
Re: BT CLOUD ERRORS
update for me:
It's working on a web browser but not on the android smartphone app.
