Message 51 of 282
Re: Call Protect - last call number not showing
Looks like I did jinx it! Just had a call which hasn't appeared on Call Protect. Sigh.
Message 52 of 282
I don't think BT will ever solve this. It all seems to have gone quiet from their point of view. But we will keep posting our updates.
Message 53 of 282
Hi @Clarkatron my colleague @RobbieMac sent you a private message last week. If you could reply to that with the requested info, it will help with the investigation.
Neil
Message 54 of 282
I've had 2 messages from you and 2 from DavidM. Nothing from Robbie. Last private message was on 29th April from DavidM which I responded to.
Message 55 of 282
Swatty how we doing? The whole scenario is still being investigated I've just been informed. Any updates from yourself?
Message 56 of 282
Still good for me, what shows on caller id corresponds to call protect.  Even with city fibre cutting the 20 pr cable feed our houses ( but that's another story)
Message 57 of 282
Hi there,
I also had a message to say they were still investigating but my 'call would be closed', which seems a bit odd. Anyway, to recap, between the 3rd and the 9th May I had seven calls; all but one appeared in Call Protect and since the10th I have only had two calls but both appeared. I guess I'll keep monitoring as they say they are still investigating...
Message 58 of 282
Thanks for update. We will keep monitoring!
Message 59 of 282
Just had a call protect fail to log call.  First in a few weeks
Message 60 of 282
I had a call earlier which has appeared on Call Protect, but I will continue monitoring as it's clearly still not completely reliable.
